I almost bought a intake like that, Is that the short ram intake? They had it on B/O and others were saying the aftermarket DBW throttle bodies were problematic. So I gave up...
it's a mid length , and i bought it w/out TB . Those aftermarket TB's are problematic , the throttle shaft leaks and its hard to get a deceit idle .i bought a Holly Sniper 90mm and used it ( stock is 78mm ) .I didn't want to go to big since i am stock , no cam , no headersI almost bought a intake like that, Is that the short ram intake? They had it on B/O and others were saying the aftermarket DBW throttle bodies were problematic. So I gave up...
Awesome! Thank you.The 4" tubing I purchased from local speed shop/fabricator. He had 2 4" elbows available, 1 small bend & 1 large bend. I picked up a 6" of straight tube & both elbow's, I returned the small elbow.
The couplers are Spectra performance part # 9771, the MAF adapter is a spectra performance 9774. Both were purchased from Amazon. The 110 degree elbow was purchased from Ebay.
The K&N air filter I purchased from the local Advance auto parts.
If I was to do it again I would get a large 4" elbow only. There was enough material cut off of it to make the straight piece out of.
I'm using a Delphi AF10043. It's the common truck 5 wire sensor that includes the intake air sensor.Awesome! Thank you.
1 more question... what MAF are you using, and, does it use the factory connector?
Is that a camaro intake tube. I picked up one to do something similar to your intake. The problem I see on my setup is the 90 stick out to far and hits the fan shroud.I moved my reservoir up and back to clear the intake. Keeps the hose short and protected and out of sight. Not quite done yet but it runs.
The 90 degree piece off the throttle body is from a GTO (06 I think) the 45 is off the kit SSandfish posted above, my buddy had parts left over from an earlier project. The end 90 degree boot and coupler are from Spetre I got from Amazon.Is that a camaro intake tube. I picked up one to do something similar to your intake. The problem I see on my setup is the 90 stick out to far and hits the fan shroud.
