I guess Ill just have to get another a/f gauge and read what the difference is between the two at the same time
BTW How does the O2S work anyways????? The only thing I know is that its sort of like a variable resistor, that changes the voltage readings......Does it maybe read the amount of heat in the exhaust and through some calculations convert it to an a/f ratio #????? IDK, Never knew this could be such a good subject.
O yeah syclonedave thanks for the pics and dyno#...your setup is SWWEEETTTT!!!! Ill email you a few qustions about your setup.
