89 s10 4.3 v6 here....Im wanting to replace my factory air cleaner (& the plastic 'snorkel' type stuff) but my question is what would i do with the tube that goes from the bottom of the snorkel/air intake that goes into the exhaust manifold on the side of the motor ? .....what is that even for anyway also please ? (Also my motor os all factory 89' stiff still if that helps)
2003 GMC Sonoma SLS extended cab 4.3L auto 4x4
What are you planning to replace it with and what is the reason? Those answers may help others provide viable options.
Just a round type air cleaner...nothing fancy just better looking is all...just like something u may see on top of a hot rod with a carb (which mine has)
94 4x4,01 Blazer
2001 Blazer 4dr 4wd LT
the heat riser tube is there to assit your engine warm up during cold weather.
Ok so will it affect anything when/if i remove it for the other style air cleaner ? I dont think it will, will it ?
time to get cereal
Would probably make it a little harder to start and idle when cold. I don't miss cold morning startups with a carb and manual choke, lol.
