1 - 11 of 11 Posts
s-series #2?
gone
looking at pulling out the tired bus wheel I have in there now, trying to decide diameter.
pics with diameter, opinions, post them up.
what's the stock size anyways?
And this will be going into a 98, do i need to think about something special for adapters?
That 3D picture dude guy
you use the same adapter you would use for the 94-97's. only reason you cant find adapters for 98+ is due to the fact that they cannot market anything that will modify the airbag systems on the 98+ trucks. but, the 94-97s use the same splines and everything, so its a direct fit.
Carolina Custom AUTOWORKS
ur correct.. because i had a 96 and i put in a 98 column with tilt and it went right on..
NO REGRETS
like stated, stock size is 15.5". you can get billet specialties wheels in either 15.5 or 14". most of the ones you see are 14"
and billet specialties has a newer adapter too. its labeled as 96-03(non-airbag)
4x4 v6 blazer
Dang near all the s-10s within the correct gen use the same adapter. They just can't legally list them as working on a truck with airbags since your not supposed to remove safety equipment.
1 - 11 of 11 Posts
