Trying to figure out where this goes on the aftermarket radio or harness since it’s directly attached in factory radio. Also, factory radio has 2 wires, new harness has 1 and wiring diagram I’ve found on forum shows one. Thanks for the help
351438
351439
Premium Member
That has to be an early 1st gen, you should specify year since that looks nothing like the later year 1st gens.
Registered Hoosier
I think that connector was for the clock constant power.
94 4x4,01 Blazer
2001 Blazer 4dr 4wd LT
yellow was constant memory or illumination ,been awhile- check the truck side of the plug for voltage with key off then with lights on- if when off its constant.
