LOOKING TO DO A V8 350 SWAP ""
HAD THIS CSE S10 FOR 6 YEARS NOW !
IT IS AN AUTO 4X4 2.8 ""
WANT TO CONVERT IT TOO--
V8 4X4 MANUAL!
WHERE CAN I GO TO GET THE INFO TOO WORK THIS ?
AND--SHOULD I BUY A MANUAL S10 TO START WITH ?
THE BEGINNING TO DATE ""
2.8 HAS DIED
V8 4X4 MANUAL!
2.8 HAS DIED View attachment 335737
Look at the V8 section of the forum. Read every article and take notes. Swapping a 4wd to V8 and converting to manual is learning to swim in the deep end of the pool. Good luck on your project.
When you get going start a build thread so we can follow the progress and add pointers as you go.
YES" Its going to be alot of work --But--I love this truck so I am on it !
I will try to post up and write in my progress !
I bought a S10 manual written by mike knell
I am hoping it will get me thru this build !
Hey guys I am soon going to be going to a junkyard around town and would like to have a list of all the cars or trucks that have a transmission in them that will fit the 2.8 s10 blazer 4x2. Also will the transmissions out of the V6 camaro 3.4 work on the blazer? I have a 1986 2.8 Blazer 4x2...
Can someone help me I have a 89s10 and my transmission went out... it's a 700r4 automatic, I found another 700r4 out of a 95 s10 when I had both of them out I compared them and the new one has some kind of electric shift and I think overdrive were as my old one doesnt... can I still make it work...
Whats up everyone,
Im having an overheating problem. This is the second time this has happened so I'm starting from the beginning again but have some questions.
My 83 2.8 v6 started overheating a few days ago. So far i changed the radiator cap and the thermostat and it still overheats. Ive...
Hi all, first post.
I have a 1984 S10 Durango that I picked up for a song. Carbureted 2.8l 5spd. I love it. However, I don't trust the engine and trans.
I found a 1993 S10 with lower km that I also got on the cheap. The body and box are rotted out, but I believe the driveline is solid.
I...
It died on me today, coasting up to a stop sign. Oil pressure, temp, volts, fuel all looked good. It cranks but doesn’t fire. I can see fuel squirting into the bowl so the fuel is getting that far at least.
I’ve been needing to tune it up for a while now. It’s been cranky on cold starts. So...
