1 - 2 of 2 Posts
By passed low pressure switch to engage clutch, tried to charge thru ac gauges low side. Compressor not sucking in freon,tried one of those quickie dispensers just in case there was a problem with cheap HF gauges. It still wouldn't take gas. I suspect a problem within the compressor. I've had a course in ac but no expert by any means, I suspect a problem within the compressor itself. Anyone had the same problem and found a fix?
Premium Member
Has it ever worked? You can check for power at the compressor clutch or put power straight to it to see if the clutch will engage.
1 - 2 of 2 Posts
