My 91 originally had ac, but I'm pulling the ac and just having heat. My question is, what do I need to do for wiring? I have a heat only climate control and some of the wires coming off of the fan control switch are going to the plug doing to the ac. Do I need to run those wires to the heater coil? I know some of you guys have done this, can someone steer mr in the right direction, or maybe hook me up with some pics?
Thanks for any help!
i saw what you did there!
the blower motor wiring would be same as far as switch and speeds go
do you have a donor truck with factory a/c delete to take wiring from?
Electrical Mod
There's really not a hole lot you need to do, honestly, it'll just be easier to pull all of the wiring to the side and tape it all up so it can't be shorted out on anything. If you plug in the new panel, I believe the a/c wiring will no longer get any power.
I got all my stuff from a friend and the junk yard so I don't have a donor truck. Next time I go up to the junk yard I'll look at the truck the suff came out of.
I just wasn't sure if any of the wires going to the ac coil needed to now go to the heater. I'll just cap off the wires and tape them up. Thanks for the help!
