1 - 2 of 2 Posts
2003 S-10: ABS pump suddenly runs all the time. Even runs with ignition turned off! I pulled the 60 amp fuse so now ABS is disabled. Is this a problem in the pump assembly or could it be from some sensor malfunction? My friends tell me replacing the pump assembly is very expensive.
94 s10 in progress
find someone with a tech II. or a abs code reader
1 - 2 of 2 Posts
