So I have been having an issue with my ABS light and the inspect brake light. The code description was a bad module solenoid. The lights would come on and turn off at random but most of the time they were on. I was tempted to send the ABS unit to Modulemaster.com but as I read on, they use “trained technicians” meaning anyone can do it (I have a Kelsey Hayes 325 module which they say is repairable). So I took the module off and popped off the lid, which was glued on, All the solenoids tested good but I found 5 bad/cracked solder spots. 4 were where the power comes into the unit and the other one was next to the J on that barcode sticker. I soldered them all, put the lid back on with some gasket glue stuff I had, installed the unit. It took a little over an hour for this fix. I had all my codes cleared and a few days later I still have no warning lights on. I am fairly confident that this fixed the issue. I had trouble getting pictures of the cracks but I think you should be able to see them.
