Hi,
My ABS light is on and off as the way it wants. When I start my car it is usually on... then I drive a bit and after the car is warmed up and I switch from D to P the light goes off. Then sometimes when I change between P, R, N and D it goes on. Has anyone occured to this problem? Thanks for the help and if there is any reference to an older post with this kind of a problem then I would really appreciate it.
Martin
Most likely a bad front wheel sensor. Not a guarantee, but 90% of the time that's the issue.
is it just the ABS light or does the Brake light(same one on dash that comes on when you push the emergency brake) come on too?
could be the module,famous for cold solder joints cracking and giving an intermittent trouble code
Ok so I did some research with the new information I got from you. Im heading to try to fix the module joints... lets hope this works. I will let you guys know.
