1 - 11 of 11 Posts
My ABS an Brake light set .
Code is C-0265
It says thats the brake controller module circuit.
Wondering if the mismatched tires I have on it are causing it.
245-60s and 235- 70s.
I would think that the mismatch would be setting a wheel speed
sensor code not a brake controller module one.
An incorrectly matched set of tires would throw a wheel speed sensor code. The difference in sidewall height between a 245/60 and a 235/70 is not enough to where you would be getting a wheel speed DTC.
The C0265 code that you have, refers to the EBCM itself. Basically, your EBCM is crapping out. I have been fixing these EBCMs for a while now, PM me for details.
Better post-em.
haha dont need ABS anyways if you have common sense and "practice" in winter haha i prefer to "pulse" my brakes and slide for 40 feet let off straighten out and slide more haha
Ripping out the ABS in a vehicle that has no weight over the rear tires is a bad idea. It doesn't take much to lock up those rear wheels.
1 - 11 of 11 Posts
