Okay, my speedometer or odometer havent worked since I bought my truck...every once in a while my brake light will blink in this pattern...one long blink then 9 short blinks....from what I have read on here it is a high VSS output or something??? So, if I get a new VSS, should this stop? Will my speedo and odo begin to work again?
FYI...it is a 1991 Tahoe, 2.8L, 5spd
ASE certified MasterTech
CHeck the 15A brake fuse in the fuse block first.
The ABS light blinking has nothing to do with the VSS,most likely your ABS module is bad,just un plug it,its only RWABS anyway!
I can look the ABS code 10 up for ya.
okay, I checked the fuse and it was not blown, When I pulled it and started the truck, the brake light just stayed on and didnt blink. So are you saying just unplug the module???
