What are the possibilities to have triggered my ABS and brake lights on intermittently?
Usually no light when you first started the car, then within 5-10 minutes into the drive it triggered the lights.
Any help will be appreciated.
More then likely you abs module has a bod solder joint with a crack. Google about that. Lots of info a fairly easy to fix.
Sent from my iPhone using Tapatalk Pro
If both brake and ABS come on solid or intermittent @992drjimmy is correct that it's likely the old ABS module poor solder issue. Very common occurrence on S-series. You Tube has a bunch of video how to's or look on eBay for a place that will repair the board if you aren't comfortable soldering on printed circuit boards. Helps to see the cracks if you use a magnifying glass.
Thank you all for chiming in. Guess I have work to do.
