I have a 95 x-cab and i put a 3 inch drop from ground force on it. I have blocks in the rear and need to put shims on. I got the shims from www.stealthconversions.com and they are telling me to buy their blocks any suggestions on how i could make it all tie together.
Well you could drill out the center hole in the shim bigger and that'd probably make the shim fit onto your current block, but I'd just get their drop blocks. since you already have u-bolts see if they'll sell you a set w/o u-bolts.
