whats their website i lost it:cs:
I work at Van & Truck World in Mississauga, Ontario and I install ARE LSII Tonneau's all the time... you can get a weather strip seal called "Weather-Gate" which you put between the tailgate and the bed... when you close the gate it's a perfect seal. Also... when the lid itself is installed there is a foam seal that gets put on the lid that seals the bed completely. If it is installed correctly it should not leak.Rick X said:Thanks for the info man.
I'm planning to install an A.R.E. soon.
I need 99.9% weather-seal, so I'm gonna seal the tailgate opening with silicone caulk for now and just not open the gate.
Later I'll try to fab an insert to go in the space around the gate that'll hold a weather-gasket, so the gate'll be usable again.
