-so before i removed the vacuum actuater (to throw it away) i looked at the vacuum line to the actuator and i saw it was a little bit damaged..!
i cut a little bit off and put it back to the activator-
(by this i saw another one!? hanging around-dont know what it is for -or where to put it...)
went back in the car started it and---
the frontwheel lights were on(even the shifter was still in 2wd
:confused: )- i looked at the actuator and the vacuum was now pulling the cad cable!?
went to drive -pulled in 4wd hi-nothing noticable...-stop-N-4wd lo-drive and 4x4 WORKS!!!
:D
BUT-when shifting back in 2wd the front wheel lights are still on-IS THIS NORMAL???
sorry to confuse u again with this thing but maybe ill can fix it before throwing away...?
peter
I'm glad to see you got your 4x4 working! The light staying on in 4x2 is normal, although it should not stay on all the time. If you come out of 4x4 and shift into reverse sometimes it helps disengauging the hubs. I know you shouldn't have to being auto locking and all but try it ,it might work
