1 - 12 of 12 Posts
Hey all, im finally going to change out my injectors. 2.2L
My question is, since its so tight, i literally cant see wtf..... is it possible to just remove the fuel rail?
Or do you remove the whole intake?
Any tips/tricks?
Thanks in advance :D
What engine?
time to get cereal
Engine type would help... I'm guessing it's a 2.2L by the mention of a fuel rail.
time to get cereal
You might be able to get the rail off by itself, but the manifold will probably need to be cleaned out as well. That area is much easier to work in on trucks without AC.
Ive been trying to pull the rail. But I think im going to pull the intake aswell and check the gasket. But definitely yes IT IS TIGHT!!!!! (truck has A/C) :( :( :(
I dont see how i will be able to do it without lifting the motor.
Any tips?
time to get cereal
Not sure, I did it without lifting the motor though. Being skinny helps, lol.
time to get cereal
Lol, yes that should do it. It's possible without doing that though, just tight.
It's mostly BS
It's definitely tight, I did most of the work thru the wheel well. If you are taking off the intake, it can't hurt to get a new gasket.
Discussion Starter #11
Oh yes, my intake gasket was toast! I dont know how it was running so good. :eek:
Glad I took the left side of the AC box off. It was FULL of leaves.
Thanks
Discussion Starter #12
FYI, anyone needing to remove the (plastic) intake on a 2.2L with AC, pull the AC box. At least the engine side of it. Makes the intake install SOOO much easier.
1 - 12 of 12 Posts
