Need to calibrate the thermometer display above the rear view mirror. It normally shaows ambient as 8 degrees warmer than actual outside air temperature.
Where is the sensor? How do I calibrate it? Owner's manual only says how to calibrate compass!
In a matter of time...
You can't calibrate it. The only thing you're going to be able to do is move it aruond under your engine, it sounds like it's picking heat up frmo your engine, try and move it forward more and into a stream of air.
Thanks for responding.
It's read wrong since I bought it used 2 1/2 years ago.
What does it look like?
If I can find it, I'll move it away from heat sources.
