1 - 15 of 15 Posts
Representin G-ville
i need help with which wire to hook the tach sending wire to on the computer. autometer said pin 10 on the black connector white wire, i tried that and it reads zero, maybe the wrong pin 10? please help
1999 s10 2.2l
You got the right plug and right pin, tach feed. Are you sure the tach works, I wire an old Sun tach to that same wire and works great.
when i went to install my auto meter tach,i had the same problem,would get power,but it stayed at zero.i was told by autometer that the 98+ was like a 2 square wave or something like that and i needed a tach adapter for it
true but i don't know anything about where to start looking for it on the computer side. it may go through the coil module after/before the computer, so it may make a difference where you get the wire at.
doest make a difference.i tried both at the cluster and the ecm.it's the same.gm used a square wave voltage pattern on the 98+'s so u have to get a tach adapter.
no you don't i have a 2000 hombre and i hooked my shift light directly into the harness in the dash. no problems, works fine.
1 - 15 of 15 Posts
