My 97 sonoma v6 4x4 keeps killing batteries while parked. Started with it died and wasn't charging while driving so I put a new battery and alternator in it and if it's parked for 2-3 days it completely drains the battery to nothing. I did a draw test with my meter through the battery ground cable, pulling each fuse and no difference to know where it might be coming from.
Also something weird is when I try and recharge the battery, my charger won't charge it unless I unhook the cables from battery I've noticed. Could the ground cable be bad ?
Sorry rushing to type this at work so might of left some things out. Any advice would be helpful
'97....probably original cables and time for a change. They can look fine on the outside, but are corroded on the inside.
Engineer
2003 S10 4.3L 4wd Crew Cab
I've had this problem for years and have yet to find a good solution. Replaced all the battery cables with 0awg. Got tired of nothing fixing it. Now I just have a separate battery pack for my solar panel and a battery isolator relay and it never dies. You might just need to leave it on a charger whenever you let it sit for a while.
A good solution is a parasitic draw test to find what circuit has the issue and fixing it.
That's what the video in post #4 explains how to do.
