Chrome sucks-Get over it!
This is a repost from another forum, but no one responded...
My A/C won't work. I just recharged my truck, and its at 45 psi on the low side. I can turn my HVAC off and on, but thats pretty much all it does. It blows air through the dash vents and the floor, but that's it.
I did some guessing about the HVAC system, and some searching and found out that the HVAC panel is vacuum powered. I am capable of replacing the hoses, but I need to know what to buy, and where all it's routed in my truck.
Thanks,
Eric
Hello there!
First you should check under the hood for broken hoses. From the throttle body to the driver's side of the truck there should be a small hose that runs into a check valve, from the check valve it breaks off into the vacuum ball and the other end i think goes through the firewall.
Well, my vents now work correctly, and I'm assuming my brakes will now function as well...but still no A/C and I'm hearing a clanging noise once in a while?!
Any ideas?
Thanks,
Eric
Its coming from under the hood, and it sounds like chains hitting each other...its only sometimes when I rev it...I didn't have the truck running for long enough to make it consistent though.
Eric
Even better...my F*CKIN truck sucks. I heard a noise under my hood when the truck was off...turns out there's a leak from somewhere around my compressor...I think its shot :(
I want A/C so bad but I can't afford to buy a new damn compressor.
Eric
Better post-em.
ahhh welcome to my hot a/c less world, hope your windows roll down. but ya ive heard that the compresors are notorios for going out like that, just like the fuel sender unit.
Discussion Starter #8
I hear you on that, my POS truck did THAT one right after I got it. I spent 3k on my s10 with no PW/PL/etc. with 104k miles on it. 6 months after I got the truck, In a period of 10 days, I paid 97 bucks for dexcool/rad hose/etc, 600 for fuel pump/sender, and a week later 600 for a headgasket...all the while I have no damn AC to go with it! This is likely the last GM vehicle I'll buy.
Eric
Discussion Starter #9
Oh yeah, and I've been without AC since I got the truck, I just finally decided to refill the system and found out the compressor blows balls.
Eric
