Status
Not open for further replies.
1 - 12 of 12 Posts
Does anyone have these handy or know where I can get it? I need to know the color code for the wiring going to the rear harness for the tail lights/license plate lights. Most importantly:
R turn signal
L turn signal
running lights
brake lights
reverse lights
plate lights
and any corresponding grounds
Canyon Carver
2002 S-10(pick-up)
Park Turn Signal Lamp - LR
YEL - Turn Signal Supply Voltage
BRN - Park Lamps Supply Voltage
BLK - Ground
Park Turn Signal Lamp - RR
DK GRN - Turn Signal Supply Voltage
BRN/WHT - Park Lamps Supply Voltage
BLK - Ground
Marker Lamp - LR
BLK - Ground
Marker Lamp - RR
BLK - Ground
License Lamp - LR
BLK - Ground
License Lamp - RR
BLK - Ground
Backip Lamp - LR
LT GRN - Backup Lamp Supply Voltage
BLK - Ground
Backup Lamp - RR
BLK - Ground
s10cyncrvr said:
2002 S-10(pick-up)
BLK - Ground
BLK - Ground
Marker Lamp - LR
BLK - Ground
Marker Lamp - RR
BLK - Ground
License Lamp - LR
BLK - Ground
License Lamp - RR
BLK - Ground
Backip Lamp - LR
BLK - Ground
Backup Lamp - RR
BLK - Ground
Thanks! YOu're the man!
Canyon Carver
orangesonoma said:
you copy and pasted for a 02 s10..he has 96...in 96 the brown and white wire does not exist...i may be wrong but im sure it is 98 and up that has the brown and white wire...
but the turn signal and reverse sound correct
I just have the shop manuals for the 2002. I figured that would put him in the right direction, if they are different he can ask again. That's why I put the 2002(pickup) at the top.
I'd really like to know the same for a 2000 S10 pickup 5-speed. Mostly I would like to tap into the reverse wire and mount a small light on my bumper that comes on only when I put the truck in Reverse. Is that possible?
ZR2 member
orangesonoma said:
brown is parking lights
black is ground
dk green is right turn/brake
yellow is left turn/brake
and lt green is reverse
Right there in front of you.Most trailer wiring is universal across all makes.
the colors are indicated above but yes you just tap into the reverse light + and run it to your mounted light, and ground it to the mount of the light if its metal. if you have any issues with blowing fuses you may have to incorporate a relay system but you should be ok.
You really should look at the dates on posts before replying.
Unless you honestly think he gives a xxxx 14 years later.
1 - 12 of 12 Posts
Status
