Registered (Ab) User
Your going to need the '96 CSFI, the harness, and the PCM to run it. I'm not sure about differences in the sensors, but there probably are differences. In '98 they changed to a different data bus, so instrument cluster is different. IDK about running an older tranny on a '96+PCM.
It could get difficult in a hurry!
Gaaoooooo
Yup more than it's worth, the biggest limiting factor is that the CPI manifold has 6 bolts per side whereas the 96+ heads only have 4 bolt holes in different locations obviously. I'd say leave it alone.
