I removed the instrument cluster & now the speedometer doesn't work. All fuses check out OK. I removed the cluster once again to reseat electrical connnectors, still doesn't work. Any ideas?
I know that the instrument cluster is sensitive to static electricity and it can damage the gauges. Maybe you didn't discharge the static electricity in your hand prior to handling the instrument cluster. You can build static electricity by simply moving about in your drivers seat.
