I have a 95 sonoma highrider and just replaced the heater core so I had the dash out and when I reinstalled the instrument panel is not working properly only gauge that moves is temp and not accurate all other gauges dead. Did have to jump start it with a old charger then once started noticed the gauges where not working. Fuse 4 is good and never popped. Could I have missed a ground somewhere or maybe fried the cluster and does anyone know how to ohm test the cluster. Thanks Bros...
Lifelong S-10 Owner
Your entire gauge cluster plugs into a socket behind the cluster. Also the printed circuit board can get loose from the plastic part of the plug. Try to make sure this is all connected completely.
IIRC there is a ground wire for the dash that screws into the metal somewhere near the center bottom edge. It's big and black. Just a screw, up from the bottom. You could always add one from the firewall to the dash. You can't over ground it.
