I have a 94 S10/SS and was told that the left rear hub is bent and the right rear axel tube is cracked at the weld they want $600.00 to fix it ! someone told me that a 4X4 rear axel is the same thing and if thats true I can get one at the local pick your own part yard way cheeper ! any thoughts on what
i was told ?
Thanks
goin broke but n style
any 2wd rear will work for you. your SS is nothing special when it comes to rear ends. like stated 4wd rear are 2" wider per side than your 2wd
NOW maybe the time to go ahead and get the ratio you want if you want to change it. 98+ blazer will have rear disc.
Premium Member
Yours has a locking 3.42 rear end which is option code GU6. (G80 for locking differential). So if you do get one from a junkyard I'd look for those codes in the glove box.
