1 - 10 of 10 Posts
MECP Certified
well i got my '99 s-10 ss rims the other day and went to put em on today and they don't fit right...it ends up leaving a gap around the rim and the roter....what it is, is that there is a small ring that is molded into the roter that doesn't allow the wheel from going on all the way...and on the rim there is a lip making the center hole a lil bit smaller, so what's gonna have to be done, i'm gonna have to have that little lip machined off....
only after you guys told me they'd fit just fine :(
someone just kick me in the nuts about now .... i'm so depressed
K
Guest
in theory they should fit right up ...because....they are all the same..but the ss...have a different suspension package and a different brake package i belive..this may be where your problem lies..i still don't understand your problem completely..maybe take some pics to help us out...but...you will probably end up needing spacers
I don't know if this is the same problem, but I have heard somewhere that with the xtreme rims on a 94-97 you need to hollow out part of the rim so it fits right... but I don't know if this applies to the SS rims. I'd find someone that has done the swap and pm them.
DogP
SoCal Mini-Trucker n FL
I had the same prob when I went to put on a set of Xtreme rims on my '97 Jimmy. I had to have a shop that does mods to rims mill out the inside of the rims just enough for them to fit on over the lip on the hubs. It only cost me 90.00, and I'm sure if you check around some local tire/rim shops, they'll hook you up. Hope this helps you out bro. L8a
MECP Certified
well i dunno waht i'm gonna do now...i'm debating between getting them taken care of which would cost $8 a rim, but i would also have to pay to have the rubber taken off then put back on and rebalanced, or just saying screw it all and get rid of them...
MECP Certified
what would it take to possibly grind it out yourself?
You can't do it yourself bcuz you have to turn them on a lathe to get them centered. Otherwise your rims would be off balance, and be a problem. I had mine done without taken the tires off, and it only took them an hour.
I've heard on other forums of people using a "flap wheel" on a drill to open up the hole a little bit. Seems to me that it would be pretty simple to do and would make the hole almost perfect. The flap wheels are a drill attachment with sand paper flaps attached. Just a suggestion.
Jeff
MECP Certified
Discussion Starter #10
well i went ahead and had em machined down, had to have the tires taken off to do so, but i did it anyways...they are at the tire shop today awaiting the new set of rubber that hadda be special ordered in (Cooper Cobra 235/55/16) and should be done this coming Wednesday...i'll post some pictures once i get em on.
1 - 10 of 10 Posts
