Sup guys latly i been having problems startin my engine. I had my fuel pump die on me last summer and then i put a new one in. I need to know what the fuel Pressure is suppost to be to startt eh truck. I read on a site it should be like 55-60 to start the truck. I just tested mine and im gettin like 40psi when cranking the engine then slowly climbs to like 55-60 then the engine starts. then at idle its 54. does anyone know what its suppost to be and what my problem would be. possibly fuel pump??
What's in a name?....
That sounds alright. The pressure is supposed to be between 60-64, I believe, with up to a 7psi drop as acceptable when it's idling.......I think my numbers are right on that one....
wow 60-64. my truck starts at 40 idles at 54 and when i give it gas its 60. do you think this is ok or is it starting to go. cause the engine is being hard to start.
TnHombre said:
starting it up at 40 sounds low to me...
it is
it should prime to 55-65, and hold it when the pump stops
It was written "when cranking", not priming. Try just turning the key to the "on" position and see what it reads.
also it doesnt do it everytime. Only if the engine sit for like maybe4 hours or longer. If i turn it on and the engines runs, then turn it off and turn it back on again it fires right up. Could i be loosing pressure with in that 4 hour time slot. ??
