The truck typically runs really well, especially above 2000 RPM's. It runs a little rich at idle, has a miss, died on my way home the other night and I was unable to get it to start. Had it towed, the last couple days I have gone out and started it but it will shut off after about 10 to 15 seconds. At a bit of a loss, not sure where to start as I've already replaced plugs wires cap rotor ignition coil. Recorded a clip but the files too large to upload
i'd say check your fuel pressure while running, filter is probably clogged all the time then sucking itself completely closed after running a bit
