Looks like you lucked out. Just switch out that yoke for whatever flange or yoke you need to work with your driveshaft and you should be golden.
I don't think that yoke will work with a CV joint. And it's definitely not a 1310 u-joint, which I'm guessing your new driveshaft has.
Yeah I'm still debating on it. I did cut the shock tabs off the dana30 pretty clean, I could use those. As you see I just flipped the ubolt bracket and swapped sides. I definitely want to get some matching Bilstein B8 for the rear, just need to see if they have a model that will work with where the lower shock mounts are now.If you don't want to buy new shocks, you can weld shock mounts down a little lower on the axle tube so they're extended more at ride height. Even if you are going to buy new shocks, it will let you use longer ones.
It looks like that worked pretty well. I don't really know how strong those stock shock mounts are, though. If you're going to be bouncing around much, you may still want to upgrade to some heavier-duty welded ones. I usually buy all those kinds of parts from Ruffstuff Specialties because they're closest to me, but WFO Concepts and Barnes 4WD are also good.Yeah I'm still debating on it. I did cut the shock tabs off the dana30 pretty clean, I could use those. As you see I just flipped the ubolt bracket and swapped sides.
I think the ones on my Blazer are Skyjackers. Not even the gas ones, just the cheapest ones. 99% of what I do is rock crawling, so they don't really matter that much. But they actually ride decently on the street, too.Do you like the bilstein shocks? I read fox are better but wear out faster. I went with the happy medium.
