I have three 24v 4.0AH and one 24v 2.0AH. This is all i got done before i needed to recharge the batteries. I wasn't thinking before i started with the cutoff wheel and used it for the majority of it, should have sawsall the brackets off and saved batteries...smh. next round i should be at least done with this side and half the driver side and then slide the axle under it when its all grounded off on both sides. Then I'll see where im at. Kinda confused with the Wagoneer springs, if i cut the sway bar brackets off or mount it in front of it. Guess it all depends on the center line of the axle in the wheel wells. I was hoping to leave the sway bar brackets to hopefully reuse them for a traction bar.
