hey ,
I have a 92 4.3 and i popped the original engine .. so i put in a rebuild and it overheats.. i changed the thermostat, waterpump , and clutch fan ..
Is there any ideas on what it could be or how to test it ????
QuickerPICKerUPer
Its not a Jasper is it? those engines are notorious for overheating.
Ok .. it is not a jasper...
I had the engine idle for 15mins. and it was fine but as soon as i went on the road with it it heats up .. within 2 kms ..
The rad is the only thing left to change.. but i wanted to see if anyone else had any ideas
Thanks
overheating
my 92 was runnung hot too after i changed the heatercore,i drained some of the "new antifreeze" i had just changed and beefed it up with a stronger solution of zerex the green stuff.i checked it with the antifreeze tester to make it much stronger i dont know the exact mix but if you test yours you may see what your protected to in degrees it may help
as long as the thermostat it opening correctly, and the fan is turning on, i would definatly be looking at the rad. when was the last time it was flushed? might need to have it pulled and a tank pulled off and core rodded out. may just be able to flush it out as well
