1 - 2 of 2 Posts
I am lifting my truck 2.5inches and am looking to upgrade my rims and tires to 31 inches tire and 15-16 inch rims. I looked at the offset recommended and it says 50mm stock. Is that correct? I can’t seem to find any pro comps or steel rims with this information. My rims now poke out 1 inch in the front and are tucked 3 inch in the back. If I go with 0 offset my back rims will be even but my fronts will stick out 3 inches total. How do I get around this? PLEASE HELP! This is driving me insane!
91 S10 4.3L 4WD Standard Cab
You are correct the stock 4wd wheels are 2" positive offset or 50mm. And you are also correct that the aftermarket doesn't make any except a variation of the Outlaw II. Which is essentially the stock 1st gen 4wd mag wheel. Some later Camaro and Corvette wheels have the correct offset since they essentially use a FWD wheel. Not much in 15 or 16, tho. C4's were 17.
1 - 2 of 2 Posts
