Please help after starting my truck it idles fine in park and drives fine but as soon as I go from park to reverse or park to drive my RPMs drop and the truck dies unless I quick tap the gas and keep the RPMs up is this a idle issue or injector issue anyone familiar?
Holy run on sentence Batman... A little punctuation would be great.
Moved to 262/4.3.
Things to check (in order of likelihood):
  • fuel pressure
  • open up the TBI and look at the fuel pressure regulator spring to see if it's broken
  • look at the injector spray pattern under a timing light to see if it's dripping
  • Remove and clean the EGR, then check that it works properly
  • Remove and clean the IAC valve
  • Remove the transmission valve body and see if any of the check balls are stuck in the separator plate. Replace filter and fluid while you're doing this.
  • Inspect springs in the transmission valve body to see if any are broken
