88s10 has been shaking and will surge or just stall out soon as I shove the clutch in and while slowing down . Problem started a few months ago. It’s steadily got worse since the issues started . Seems to do it worse when it’s colder outside and it just recently started stalling out every time I shove the clutch in when slowing down . It initially would fire right back up . Lately it has been hit a miss a will fire up then die . Will do it when just idling now sometimes also . I have cleaned the throttle body , and cleaned and changed pcv valve , IAC sensor, spark plugs, wires, distributor cap and rotor button, air filter, egr valve , MAP sensor , checked for all vacuum leaks, it acts like it’s starving for fuel when slowing down. Any advice would be greatly appreciated, . Runs perfectly fine when at highways speeds .
