I Love Billet
I've searched high and low looking for some detailed pictures of the stock 2.8L vacuum diagram for my truck. The one on the radiator support is too generic and doesn't show everything on my truck. Can someone please help me? Possibly take some pictures of their bone stock setup?
Here are the pictures of mine right now (I know it's totally wrong because half the vacuum lines had sticks in them when I bought the truck so I guessed where they went when I replaced some of the lines).
This runs from the charcoal canister mounted on the core support just below and to the left of the driver's side headlight. It's hard plastic.
Vacuum ball is mounted to the driver's inner fender but isn't hooked up to anything where does it go to?
Please help me anyone? The online generic diagrams for my truck just aren't helping at all...
I Love Billet
Discussion Starter · #2 ·
These are just 2 pictures that are absolutely obvious. I'm almost positive the entire vacuum system is screwed up; including the vacuum lines behind and under the air cleaner...
Go to auto zone's site and register,they have vacuum diagrams for s10's.
i saw what you did there!
theres only a few vacuum lines on these trucks
not complicated at all
if you look by each vacum port on the TB unit you will see a cast letter
J is for EGR vacuum solenoid and really is not a big deal to have connect at all
C is PCV valve
A is to charcoal canister
S is to air cleaner solenoid motor if so equipped
and F which is the only one on the rear of the unit is for the MAP sensor
but you can use any intake manifold source for the MAP sensor
the hose to the ball will have a TEE in it and share with items such as heater control panel and such
that hose runs through the firewall on pass side by heater box and into the cab of the truck into the dash
small black line
you need it connected to intake manifold source so the dash panel will change your heater positions such as defrost, vent, floor, etc
required is the MAp sensor
or it wont run or run very good
F and C are the required ones in order to run or run correctly.
all the rest are optional
this may help:
hose sizes:
Map Sensor- 1/4"
EGR Solenoid- 3/16"
EGR Valve- 3/16"
PCV- 3/8"
Canister Top- 1/4"
Canister Bottom- 5/16"
-Y Connector- 5/16" Main, Split to 3/16" Secondary
-Canister Bottom Y (Small Hose)- 3/16"
-Canister Bottom Y (Large Hose)- 5/16"
Brake Booster- 3/8"
I Love Billet
Thanks!!! That helped alot!!! Now I just need to go buy some new hoses and hook it all up. How much of each do you think I'll need to redo it all?
I Love Billet
Also, is the blend door hose a hard plastic one as well or is it soft rubber? Does it run into the firewall behind the motor or over to the driver or passenger side of it?
