i just noticed the projects section
lol, it should be at the top of the page, not the bottom. i already have this in the v8 section, but this seems more appropriate, so ill be updating it here now.
i am keeping a photo journal on photo bucket that can be found here:
http://s222.photobucket.com/albums/dd184/hi_im_sean/s15 v8/
i pulled the motor/trans out about 3 years ago (2.8/700r4), was driving it around until then, lifted with 32x11.50s. built the motor about a 1.5 year ago and its been sitting on the stand, poor thing. the tranny is from someone who owed my dad a favor, just a rebuilt late model 700r4, i have a corvette servo for it and a tci lockup kit, nothing fancy there. pounded the firewall in when i yanked the motor(probably not enough), removed my horrible body lift from the days of being 17, and installed the larger fuel tank (20 gal?).
recently: i got the whole suspension from a 96, including front brakes, but no rear axle for $100, a prothane full kit, some por-15, chassis black and caliper paint, and all the prep chemicals. i needed stock spindles and shackles because it has 2" lift spindles and shackles id like to revert to stock, so i thought $100 was a steal, and i can take my time to paint the parts and not have the truck on jack stands. i have been working on the cluster, and wiring of the whole truck, im an electronics nut, so that part was fun for me. i cut up the evap housing for valve cover clearance. i had removed it a long time ago, maybe 2 years, i had the evap core on the front seat for all of that time, well, it got stolen recntly. went to reassemble, and it was gone! still waiting on my ebay replacement.
i dont want to hear it from you 305 stroker haters, but:
30 over stroked 305=335
vortec L31 heads in stock form, the 1.94 version cast# 12558062
94 truck block, kb hyperutectics, 9.3:1
full arp
comp 256h-12 w/ magnum roller tips 1.52:1
mallory unilite with mech and vacuum advance, it was free, was going to use hei
holley 4160
patriot shorties
blah blah blah, ask if you need to know more, nothing crazy just a nice little torqy stroker
old pic, but its fully dressed now, just need to install the oil filter adapter and shes ready to drop in
stroker clearancing
most of an s10 suspension
the rest, with a tranny
97 grand cherokee steering shaft, the colum end doesnt fit, i didnt read the jeep steering shaft thread well enough. i have a 92 cherokee shaft now as well i need to get a picture of it, its a direct replacement for the first gen s10/15. the joints and rubber damper are worn out to bad to use though, but the shaft material will work as a key to make that beautiful grand cherokee shaft work with first gen s10 colum, more on that when i attempt it.
naked control arms, proper use of sockets and extensions, and stuborn bushings
evap housing jtr valve cover clearance thingy, used rivets and some really good adhesive used in motorcyle case halves to seal it all up.
i think we all know what that is
everything unnecessary removed, and the rest labeled and separated, got a huge convoluted tubing kit, oh joy
decided to clean the cowl, i recommend you do this, the driver side wasnt draining, caught it in time, beside you find some neat stuff sometimes. i found some old bottle caps and a nice pen.
what a champ, orginal 2.8 and 700r4, seriously
teaser
street rod artic whites
exploding cluster
whats that diamond plate for?
made a template to see how it would all fit, once i decided it would all be symmetrical i came up with some mathematical assistance
cut out old gauge faces
thats what its for...
milling off the diamonds around the perimeter so the bezel sits flush, and clearnace for the column. the joys of owning a mill.
boring the holes
gauges mounted, i have the holes for the turn signals drilled now, and the turn signal lenses cut out, need to mount them and update pics
i may use the brake and brights lenses as well, may not
more to come....
full arp
holley 4160
patriot shorties
stroker clearancing
teaser
exploding cluster
boring the holes
more to come....
