Ok, well for the last 8 months i have been trying to fix a start off shudder that i just can't seem to get rid of no matter what i try. Here is what all i have tried:
- measured and set drive line angles to make sure they were correct
- made sure those angles make my u-joints phase properly
- checked my 3link for play in the bushings
- got my drive shaft re-tubed and balanced because of a ding in it
- got all new u-joints installed
- installed a new factory center support bearing
- made sure there was room for both parts of the driveshaft to slide front to back a little
- made sure the shafts arent binding at all in full range of motion
Bascially i have a sd.com super pivot 3-link installed with F9000 bags and rear shocks. My truck is a '98 ext cab with a v6, 5spd, and 2 piece drive shaft (NO double cardon joints, just regular u joints). I have shims under the tranny and center support bearing. I really dont know what else to try here. My problem is that from start, through first gear until around 25-30mph i get a bad start off shudder. I can feel it really holding the truck back and its VERY annoying, i am sure its not good for the truck either. The weird thing is that when i lift up the back of my truck all the way the shudder pretty much goes away. The farther i go down the worse it gets. From all indications it would make sense that its the drive-shaft angles or pinion angle, but my angle finder says they are fine. The only other thing i can think of is that something in the back does have some play in it that i can feel by hand and that when i lift up the truck all the way in the back that the bags put pressure on whatever is loose and makes the shudder go away. I dont think it could be a clutch or flywheel problem since it goes away when i lift up the back of the truck. I dont know, but i am ssssoooooo tired of dealing with this problem, i have worked on it every weekend for months now and just dont seem to get anywhere. Does anyone have any ideas at all? Know any good shops that could look at this kinda problem on a modified truck in FL? At this point i just want it fixed! Let me know.. thanks guys.. sorry for the long post
- Mike
- Mike
