I am looking for info on doing a 6 speed swap into my truck. I know a few things that I will have to do, but I am looking for as much info as I can find. I know the cross member has to be moved, my console will have to be changed, shortened drive shaft ect. Do I need to change the flywheel, starter, bell housing, clutch, slave cylinder? Any info would be great. thanks.
up to sumthing
yes u will need the t56 bellhousing clutch flywheel pressure plate slave cyl etc.....
also u will need a camro starter & u will have to drill & tap the block for the starter
