Executive Platinum Member
Is it possible to get 6 lug wheels on a 5 lug S10 without using the wheel adapters? I have heard you can send out the axles to get drilled, but waht about the hub and rotor? Any response would help. Thanks
[email protected]
Early Member
Hub and rotor has to be drilled also.
Ok, so have you seen this done? is there going ot be enough room on the axle flange to go from a 4.75bp to a 5.5bp? Let me know. thanks
Early Member
I couldn't tell you if it can be done. I just know if it is done, you will have to drill the rotor to do it. I would either do a search on this forum for information and/or call a local shop to see if it can be done.
