Status
Not open for further replies.
N
Guest
Ok.. So i wanna know if 5x114.3 bolt pattern wheels will fit on the 5x4.75 S10? I don'tknow the metric to standard conversion or anything.. basically, i want to put the Honda Prelude Blades (5 lug from the newer prelude) on my gf's s10.. any help?
Metric conversion for 4.75" is 120.65mm You'll need adapters to fit those on. The 114.3mm is the same as 4.5" bolt pattern. If you had a Ranger you'd be all set except you'd still need spacers since the FWD wheels are positive offset.
Status
