1 - 2 of 2 Posts
When mounting your lower link frame mounts where does the bolt hole need to be in relation to the bolt hole for the wishbone. I set up mine up by bolting the links and wishbone on and getting the axle all centered and adjusted the pinion angle so that I could just lift the brackets up and mark on the frame where they will go. They seem a little bit far foward by looking at the pics of your show chassis. I havent been able to finish the install yet so I'm not sure how the pinion angle changes throughout the travel. I am assuming that it stays pretty close to 0* right?
I am just wondering if it would be better to drop a plumb bob down from the wishbone mount to mark the lower link mounts or if the way I did it will be fine.
Afterhours Admin
if youre using the bolt-on frame brackets, theyll be 12" back from the stock rear rivit hole to the new rear bolt hole. if youre reusing the stock perches, theyre 6.75" from the rear rivit hole to the new front rivit hole.
1 - 2 of 2 Posts
