bumpin noma
Is the axle supposed to be able to go all the way up and hit the top of the notch? Mine is on jackstands right now and it doesnt go all the way up because the driveshaft hits the gas tank x-member. It'll lay before it goes up that high, but I was just wondering. I still need to shim the carrier and tranny still too. This is on 15 inch wheels with some stock tires. Sorry, no pics right now, will try and get some tomorrow.
Afterhours Admin
check your pinion angle but i have had problems with the shaft hitting the raised tank crossmember as well so i worked with jason to lift it u a bit. you may have an older crossmember or you might need it to go up further..and ya as long as it lays out before it hits youll be fine, whether it hits the notch or not depends on how much of the notch you put it in..
