1 - 12 of 12 Posts
BEL-2100
Spindles, Ductile Iron, 2 in. Drop, Buick/Chevy/GMC/Isuzu/Oldsmobile/Pontiac, Pair $142.88
$142.88 BEL-4225
Lowering Springs, Coil, Front, Silver Powdercoated, Chevy/GMC, Sonoma/S10 Blazer/S10 Pickup/S15 Jimmy, Pair $89.88
$89.88 BEL-4930
Bushing, Front Upper Spring Spacer, Polyurethane, Black, Chevy/GMC, Pickup/SUV, Each $22.39
$44.78 BEL-5954
Lowering Spring, Leaf, Rear, Gray Powdercoated, Chevy/GMC, Each $76.95
$153.90 ·The part BEL-5954 has an additional shipping charge of $6.00 per item.
BEL-6200
Lowering Block, Rear, Aluminum, 3 in. Thick, 2 1/4 in. Wide, Chevy/GMC/Isuzu/Mitsubishi/Nissan/Toyota, Kit $31.95
$31.95 BEL-7003
Shock/Strut, Nitro-Drop, Twin Tube, Front, Chevy/GMC/Isuzu, 2WD, Each $37.88
$75.76 BEL-7503
Shock/Strut, Nitro-Drop, Twin Tube, Rear, Chevy/GMC/Isuzu, 2WD/RWD, Each $37.88
$75.76
Select All
Sub Total:$614.91
Hi i was wondering if this would be all i would need for a 5/6 drop and if it would all work for my 98s15? I was also wondering if i have stuff on here i dont need or if there are cheeper parts that will work.
I hate my truck.
That looks right, dont forget more likly then not youll need new tires as well. Also if you have an ex. cab your going to want angled blocks not flat ones. Oh and to save some money in the rear you could mono leaf it and use a 2" block. Or pull a leaf and use a 3" or 4" block.
I hate my truck.
You should be able to get by with only cuttin off ur bump stops and brackets, you mayyyy need a C-notch, if you do SD has a good bolt in C notch for cheep. And I dont think youll need a spacer at all the 1st gens usually dont lean bad.
I hate my truck.
If you do lean you will only need one spacer btw.
Likes with no shine
Id go ahead a get a spacer just incase its only like 20 bucks. Thats just my opinion. Mine with a 3/4 drop leans but not to bad I didnt get a spacer and wish i had now. Oh well, dont want to rip everything off again.
1 - 12 of 12 Posts
