ok i got 245/40/18 and i want to do a 5/6 drop now i have seen the cart on here that says that will rub. how bad would it rub could i drive it for a little while till i can save up $ to get new tires
Squid Life
They are enough smaller in diameter than stock that I think you could get away with it, but the width may cause problems...I imagine those are mounted to 8" wheels...some rubbing at full lock and with a good stiff shock you might not have major problems...I had the stockies on a 4/4 with minor rubbing on big dips and large bumps, but I wouldn't call it severe...those tires are about 2"s shorter and the truck is 1" lower than mine so I would think you would have about the same rubbing problems I had with the stock tires.
"i got that slap"
you'll be fine man, i drove on 5/6 w/ 235/40/18 for 4 months with no problems just take the inner fenderwell bolt out thats directly above the tire
let me know if you need some pics....
-jeff
