141 - 155 of 155 Posts
03 GMC Sonoma SLS & 04 Chevrolet Blazer Ls
Discussion Starter · #141 · (Edited)
I decided to go with a LQ9 cam so I would not loose the bottom-end torque but gain some hp. My objective is more of a daily driver. I picked up this cam from a guy on market place.He had bought a new LQ9 and upgraded to an after market cam. So the cam was basically just a breakin hrs cam. It came with lifters seals all for $20 plus shipping. View attachment 368122
The graph for the LS6 cam above that I posted, the 5.3 he used for testing was stock with the stock truck intake. I'm sure the Dyno graph will look different on my 5.3 since I put 243 heads with + 2cc forge Pistons bumping my compressing up to 10.6.1cr and I'm going to be running the TBSS intake. So with the 243 heads and TBSS intake, I'll be flowing more air then a stock 5.3 with a cr of 9.5.1 and stock intake manifold.
Discussion Starter · #142 ·
This is not what I wanted to post today but due to circumstances beyond my control at this time my Ls swap Will be held up until March or April of next year. I will post why in off topic later today there will be plenty of foul language. I am not a happy camper.🤬
Discussion Starter · #145 ·
Some good news, today my TBSS intake arrived. Only bad thing is the engine it came off of must had some serious blow by the whole inside of the intake is well coated in oil. It's going to be fun to clean. Or they used the cheapest oil on earth that vaporizes when it gets hot. You can finger paint in the oil on the back of the throttle body that's how thick the oil is. I will post pictures after it's clean.
Discussion Starter · #146 ·
More Parts
Speedway motors 4130 chromoly steel Upper Control Arm P/N 91605012
with MOOG K5208 Ball Joints.
Automotive exterior Bicycle part Auto part Font Metal
Discussion Starter · #147 ·
My wife ordered me a custom engine cover for the TBSS intake manifold but it won't be here until after Christmas. It comes bare metal so I can put whatever color I want on it. I'm going to go to the powder coater and see how close they can get to the color on my blazer. Here's some pictures of what it looks like.
Input device Gadget Font Peripheral Cable
Motor vehicle Automotive design Hood Automotive fuel system Automotive lighting
Discussion Starter · #148 · (Edited)
Finally decided to overhaul my 4L60e using some upgrades from sonnax & Raybestos.
Parts list.
Sonnax heavy duty 3-4 clutch backing plate kit (74140-1K).
Raybestos 4L65e (6.0) friction clutch pack kit (RGPZ-005). With six .095 steels. Same one used in the 05 & 06 Chevrolet SSR 6.0L 4L65e.
Sonnax
2.84 Ratio Input Carrier Kit (77284-K) “close ratio” 1st 2.84 / 2nd 1.55 gear ratio over the stock 4L60e at 1st 3.06 & 2nd 1.63 gear ratio.
AC. Delco heavy duty rear five pinion planet (24241244).
GM transmission service gasket kit (19300335).
Sonnax
(77284-K)
Sonnax (74140-1K).
Update.01/10/2023
2004 Chevy Blazer Ls 2dr
. I am putting a 5.3L (L59) from a 03 GMC Yukon drive by wire with the summit racing Pistons Chevy performance head gaskets and 243 heads Mill down to 62 CC my compression will be 10.6.1 CR. Should work well with the 2004 LS6 Corvette camshaft I'm going to be using. And a 2006 4L60E C/N 6CPD C-Police Truck transmission from a retired NYPD fleet Chevrolet Tahoe.
Parts list.
5.3L L59 from 2003 GMC Yukon SLT.
159K Miles on it when pulled.
New GM Performance Camshaft from 2004 LS6 Corvette P/N 12565308.
Gen 3 243 64cc Heads milled down to 62cc.
DELPHI 12613412 50lb Ev6 injectors.
Chevrolet Performance Head Gaskets -12575329 Compressed Thickness 0.052 in.
Chevrolet performance valve springs P/N 19420455.
Brian Tooley Racing Rocker Arm Trunnion Upgrade Kit BTRTK001NB.
Gen IV Rods P/N 12607475.
ARP 134-3609 Performance Series Cylinder Head Bolt Kit.
ARP 134-6006 Connecting Rod Stud Kit.
Current performance Motor mounts & Blazer 2WD transmission crossmember RCS10B-700 .
GM 302-1 muscle oil pan
GM PERFORMANCE Dipstick Tube P/N 12570787
GM PERFORMANCE Dipstick P/N 12570788
Holly Blackheart
exhaust manifold P/N 7122 30 26 HKR.
2006 C/N 6CPD C-Police Truck 4L60e transmission from a retired NYPD fleet Chevrolet Tahoe with TransGo shift kit HD-GM92 TMBX torque converter for now.
Also with Sonnax heavy duty 3-4 clutch plate kit with 7 clutch pack I'm using Raybestos GPZ105 clutch set and upgraded to AC-Delco P/N (24241244) rear heavy duty 5 - pinion planetary and I order a Sonnax 77284-K front six pinion planetary it will change first and second gear ratio. First Gear Ratio: 2.84: 1, Second Gear Ratio: 1.55:1.
Holly Blackhart AC evaporator side cover P/N 71223028HKR.
LS1 Camaro / GTO water pump with LS1 Camaro / GTO harmonic balancer. With modified alternator / power steering bracket to line up with GTO harmonic balancer and water pump.
Melling M295HV High Volume Oil Pump with 60 PSI spring.
Melling BD417-DBRKT - Melling Timing Chain Dampener Bracket
Dirty Dingo DD-LS-AC-LM-CMV lower passenger side mount A/C bracket kit with Sanden SD7B10 mini compressor.
Quantum-340lph-direct-drop-in-performance-fuel-pump-assembly for 2dr 2wd Blazer P/N QFS-A822HV.
AEM
(30-4110) UEGO Air/Fuel Ratio Gauge
Summit Racing SUM-326943780-2F Forged Pistons + 2cc dome Bore 3.780.
My compression will be 10.6.1 CR.
Custom engine cover for TBSS intake manifold.
After
Suspension
Front
Belltech spindles P/N.2102 and 2/3-in drop springs P/N.23228.
Rear
Belltech 3-in drop leaf springs P/N.5964. with 1-in lowering block with2 Degree Taper P/N 6002.
Sitting on Vision-Torque 20x8.5 & 235/35/R20 Tires.
Currently Ebay vendor selling 5.3 and 6.2 gen 5 piston and rod sets(std bore) from new engines for 350. Includes rings , brns
Inexpensive compression bump up grade Bought 6.2 set last week. Pristine new GM. Check It Out !
Discussion Starter · #150 ·
I already have a set of Gen IV rods out of a 08 6.0L had my machine is check them out before I used them. What was nice with the summit racing Pistons and the Gen IV rods the piston weight was pretty close to the original 5.3 rods and pistons just over a gram difference so my machine is said not to worry about balancing it since I'm not rev it over 6500 rpm. But I'm sure it won't be that high after I have it Dyno tuned. I'm sure they're probably be more like 6200 rpm or less with the ZO6 Cam, I think it starts falling on it face after 6200 rpm in the 5.3L.
Discussion Starter · #152 ·
My 5.3 sounds great all the way to the 6800 red line, but I'm probably making terrible decisions every time I go there.
Right now I'm keeping my expectations low right now until I get it on the dyno. That way there is no disappointment.
For my Blueprint 6.2, they are stating a 6200 redline. This was also the cutoff on the dyno test.. Agreed on the power loss after 6200. HP is still up there, but torque starts to drop at 5500. Dyno chart and cam specs below. Hoping to start the swap in March/April.
Cam Specs:
.612 Intake .585 Exhaust
225 Intake / 238 Exhaust duration
@ .050 - 113 degree lobe separation, 110 ICL
Rectangle Slope Font Parallel Plot
Cam Specs:
Thats the realm of LS design that all other mfg's wish to emulate. Best in class Power band , torque curve in compact , simplistic, low cost, ultra reliable pkg. That doesn' t need engine destroying hi RPM to achieve it's specs.
The FoMoCo 7.3 godzilla is an excellent example of same architecture with wider bore spacing that shares all above except low cost. Crate variation is proving popular amongst well funded projects
