1 - 11 of 11 Posts
Hi guys, my 4x4 is not working. I checked just about all the components (even replaced the vacuum switch) but found out the vacuum actuator would not compress. So that lead my to getting under the truck to re examine the hoses. Found out that two of the hoses were dry rotted and cut in half close to where the vacuum switch meets the transfer case. Obviously these hoses need to be replaced. Does anybody know if there's a kit that I can get to replace all the hoses? if so where can get one? thanks.
Premium Member
No need for a kit, just buy replacement hose by the foot at NAPA or any parts store near you.
Okay thanks, does the diameter of the hoses matter? also how many foot of hose would you recommend if I were to replace all the hoses?
2003 GMC Sonoma SLS extended cab 4.3L auto 4x4
Yep - size does matter. IIRC, you need 5/32" & 7/32" I.D., and you can always do the fail safe empirical method - take a small piece of each size the existing with you to match. I don't recall how much length is required, but 'eyeball' it and figure a margin of error when purchasing. The hose is not a budget buster.
And replace one at a time.
Reactions: KKR27
What size Y connector do I need for the7/32 hoses?
Don't think it matters if it's shaped like a Y or a T since vacuum goes around corners. Dorman makes one.
349720
You can buy a box of 10 on ebay for $20 or 1 at a time for $13 each.
I'd spend all day in a junkyard looking for one before paying those stupid prices for a pennies worth of plastic.
Reactions: KKR27
Discussion Starter · #10 ·
Don't think it matters if it's shaped like a Y or a T since vacuum goes around corners. Dorman makes one. View attachment 349720
Alright thanks, appreciate it!
Ace hardware or Home Depot.
Reactions: KKR27
1 - 11 of 11 Posts
