I am probably ordering the hedman headers for a '92 4x4 s10 from summit here soon. It says the flange is not included...when I get the correct corresponding flange, will it bolt right up to my stock exhaust system? Or do I have to cut and weld my factory pipes to make it work? Should I use the included collector and header gaskets or should I get some better quality ones?
OH and can I install these on my new engine which is on the stand, and drop the engine in or do I have to install the engine first, then bolt the drivers side header on? What if I disconnect the steering shaft first, then can I drop in the engine with them installed? thanks
