1 - 2 of 2 Posts
First time with snow. There seems to be a problem with the transfer case dropping out of 4WD high when there is a lag or while shifting. Haven't picked up a Chilton's yet, so I was wondering if anyone here could help?
Thanks in advance.
ok. there is an adjustment for the shift lever that probably is off. its kinda hard to explain how to adjust it. on the drivers side right by the front driveshaft is where the shifter hooks up. i'm not sure if you will have to remove anything to get to it easily since they vary from year to year. but follow that linkage and there is an adjustor on it. I havent adjusted mine in about a year so my memory is a little fuzzy. but check out your chilton to make sure.
1 - 2 of 2 Posts
